RM550 is a higher quality unit, go for that one.
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/565924-help/#findComment-7436588
Hope this helps :P
*RM550x
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/565924-help/#findComment-7436602
Just now, HKZeroFive said:
*RM550x
Lol yea sorry i meant the X. xD
https://linustechtips.com/topic/565924-help/#findComment-7436606
I would definitely go with a different PSU. While I do not know the difference between the RM550 & RM550X I do know that most of Corsair RM SKUed PSUs are lower end ones. The RM550 falls into tier 3 of the PSU tier list over at Tom's. http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html I would suggest going for something from tier 1 if you plan on doing any heavy overclocking & something from tier 2 if you plan on running stock or just lightly OCing. Of course this heavily depends on the specs of build as well, if a 550w PSU is close to the actual power you need to run your rig you'll need to go with a little higher wattage PSU for OCing.
https://linustechtips.com/topic/565924-help/#findComment-7436622
1 minute ago, MarcB said:
what is the diferrence between them?
RMx uses full Japanese caps while the RM has secondary Taiwanese/Chinese caps (which are usually lower quality).
BTW, you can net a top tier PSU like the EVGA SuperNOVA 550 G2 for the price of an RM 550.
https://linustechtips.com/topic/565924-help/#findComment-7436625
Just now, Rob27shred said:
I would definitely go with a different PSU. While I do not know the difference between the RM550 & RM550X I do know that most of Corsair RM SKUed PSUs are lower end ones. The RM550 falls into tier 3 of the PSU tier list over at Tom's. http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html I would suggest going for something from tier 1 if you plan on doing any heavy overclocking & something from teir 2 if you plan on running stock or just lightly OCing. Of course this heavily depends on the specs of build as well, if a 550w PSU is close to the actual power you need to run your rig you'll need to go with a little higher wattage PSU for OCing.
RM series from Corsair is in Tier2 :)
https://linustechtips.com/topic/565924-help/#findComment-7436630
30 minutes ago, MarcB said:
Sesonic m12ii 520w is better then corsair rm 550w?
While the M12II-B 520 may offer better capacitor choice, the RM series will offer superior electrical performance, efficiency, quieter (fan not as susceptible to bearing noises, a more relax fan profile), warranty service (in the US, I found Corsair address RMAs quicker than Seasonic), etc. It's also a fully modular unit, where the M12II-B is semi-modular (unless we are talking about the Evo model). If they are in the same price point, I would go with the RM personally.
https://linustechtips.com/topic/565924-help/#findComment-7436872
