open the task manager and sort for cpu usage
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/565720-cpu-running-at-100-idle/#findComment-7434467
4 minutes ago, Dooooooots said:
@aisle9 @Bajantechnician @McHox Hey thanks. After a couple of restarts it became completely fine again.
my bitminer point may still stand though
its when a virus uses you cpu to bitcoin or whatever mine and send the coins to the hacker
could be ok for liek (as an example)10 mins, then the application could start up again.
make sure of that
https://linustechtips.com/topic/565720-cpu-running-at-100-idle/#findComment-7434515
