Hi,
So i plan to make my PC a gaming / light graphic machine and for that i need atleast 2 monitors and one will be for gaming/drawing and second will be for watchin yt or smth else. So i wanted to buy 980 gtx from geforce but my plan did change due to some reasons and now i wonder if i should buy 970 gtx lets from msi or evga or R9 390 Sapphire  ( i know many will point this as winner but before you do that hear me out to the end). IF i get 970  and plug it to 2 monitor (which will be at max 144p resolution with maybe 100 Mhz refresh rate ) and second one to my CPU integraded graphic (i got i5 6600k OC'ed to 4,4 GHz stable for now) will it be good ? OR just put r9 390 and plug 2 monitors at once straight to GPU ?
AND YES i know that r9 390 has potential to crush 970 but drivers are scarin me (and no i dont want to hear about recent nvidia's fail because they got it like once in ages unlike rads which is painful ) and i am mostly an mmo player that will propably play titles like Blade and Soul or Black Desert unless i change mind/better games wont come.
Cheers,
CPU i5 6600k 4,4Ghz , COOLER Dark Rock 3 from BQ, RAM 16 GB of ddr 4 2800MHz from corsair,
 PSU EVGA 750 W GOLD G2, MOBO Msi z170A Gaming M3, CASE NZXT H440 Black/Blue,
GPU Geforce GTX 980 Gigabyte G1 Gaming,
STORAGE 1 SSD Samsung 850 Evo 250 GB and 1 HDD 500GB WD, Windows 8.1.
https://linustechtips.com/topic/565513-multi-display-setup-question/
If you are going to game on one monitor, I would suggest to go for a 970. I know ATI has more video memory, but most games don't use more than 3.5GB VRAM right now. And even if you buy a 970, you can plug both your monitors into your GPU. 970 can take 3 displays with no sweat, as my current setup, I have 3 1080p displays, and I game only on one display. So it doesn't really matter that much.
Youtube Gaming Channel : International Gaming Forum (IGF) : https://www.youtube.com/channel/UC3kAr9J4RlOjuRVmoBRu5fQ
Intel Core i7 6700k   I   Gigabyte Z170x Gaming 5 Motherboard   I   Gskill Ripjaws V F4 3000Mhz 16GB RAM   I   Gigabyte Nvidia Geforce GTX 970 G1 Gaming   I   Samsung 850 Evo M.2 SSD
I   Samsung 850 Evo 500GB SATA SSD   I   Seagate 4TB Mechanical HDD   I   Antec H2O 1250 CPU Liquid Cooler   I   NZXT Source 530 Full Tower Chassis   I   Mad Catz Cyborg V7 Gaming Keyboard
I   Mad Catz M.M.O.T.E Gaming Mouse   I     So Basically, Oculus Ready!
If you have GPU install your CPU igpu get disabled ... i would get 390 and plug both of your monitor into GPU, it really depend what game you are playing. If you are willing to turn down some graphical settings you can reach 100fps range for newer games.
Magical Pineapples
Well i did tell what i will be playing for now LOL
maybe but 970 is so cut in its power :S
Yes, it is super power efficient, and not that noisy either!
thats not what i meant by my post earlier. What i did mean is that it has been either badly presented on market side or its hardware was cut down for some reason (3,5 GB of Vram, memory bus is not what it should be and so on ) ...
