Linear Linked List help
Go to solution Solved by CJPowell27,
Update: i threw in come random code and it worked so I guess this is solved
Hey guys, I've been trying to add a node right after the first node in a linear linked list.
However, I've been getting a seg fault from the code and I have no idea what to do, here
is my code.  Any help is appreciated, thank you so much.
http://imgur.com/nXICuuN
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/565509-linear-linked-list-help/
It is C++, I'm not sure how to do the code tags, would it help to upload to pastebin?
https://linustechtips.com/topic/565509-linear-linked-list-help/#findComment-7432041
You can add code tags in your post like this.
[code]
// Write code here
[/code]
There's also a <> icon above where you post (between the quote and spoiler options) that you can use to add it as well. When posting long pieces of code it's nice to wrap spoiler tags around it or link to another site. Pastebin, gist, and other similar sites are fine as well.
It allows people to copy/paste and run the code which can help with debugging and solving problems.
https://linustechtips.com/topic/565509-linear-linked-list-help/#findComment-7433178
https://linustechtips.com/topic/565509-linear-linked-list-help/#findComment-7433225
