I am planning to build PC strictly for the purpose of video editing and NO gaming would be done on that.
This is what I have planned- http://pcpartpicker.com/p/xC3FFT
If you have anything better please leave a PC part picker link. I have a max budget of $2250.
I need that 1TB SSD and a fanless Cooler for Silence. I am not really sure about the case and if something with good noise isolation is under $100 include that.
I need the PSU to be beefy for because I may SLI the GPU in future.
Not looking for any aesthetic and you can make the PC as ugly as possible just make sure it is silent.
Hardcore Hardware Whore | Check out my Blog for for Latest Tech News and more | Cricket Fan | Weapons Nut |
https://linustechtips.com/topic/565186-workstation-build/
You might consider the i7-5820k. It is also a 6 core processor that would work on the same motherboard. It might even save you a few bucks and you would get stronger performance per core. I think your case choice is spot on, although you could probably find a define r4 which almost the same exact case for cheaper as well. Other than those 2 thoughts your build looks pretty spot on.
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428518
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428528
21 minutes ago, abhigyan001 said:
Why do you have a more expensive 5820K with a lower frequency? I suppose it has a bit better TDP but still.
The Define S is the one built for silence, but I think you're still going to need some kind of fan on the cooler given the TDP on the X99 chips
Sentry Mix 2 Fan Controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992012
And the fire pro cards are probably going to give you more for your money, same with the SSD here
Dual Workstation GPUs isn't going to be worth it for video editing, the PSU is just there for silence.
PCPartPicker part list: http://pcpartpicker.com/p/w8WXCJ
Price breakdown by merchant: http://pcpartpicker.com/p/w8WXCJ/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($376.99 @ SuperBiiz)
CPU Cooler: Thermalright HR-22 Fanless CPU Cooler  ($86.99 @ SuperBiiz)
Motherboard: Asus X99-A/USB 3.1 ATX LGA2011-3 Motherboard  ($249.88 @ OutletPC)
Memory: Crucial 32GB (4 x 8GB) DDR4-2133 Memory  ($119.99 @ Adorama)
Storage: Sandisk Ultra II 960GB 2.5" Solid State Drive  ($234.00 @ Amazon)
Video Card: AMD FirePro W7100 8GB Video Card  ($619.99 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: Rosewill 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($176.80 @ Amazon)
Total: $1944.63
Generated by PCPartPicker 2016-03-14 03:16 EDT-0400
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428535
4 minutes ago, DrM said:
no need for the gaming GPU
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428536
1 minute ago, Streetguru said:
gaming GPU
AFAIK workstation gpus are the samething, except with ECC memory and 10x the pricetag
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428542
pretty sure the memory is the same, it's just that the cards come with way better optimized drivers for things like video editing scrubbing and they tend to support more displays for better productivity, with the fire pro cards able to handle up to 6 4k displays
if you're doing professional work you'd want one, and the W7100 costs as much as the 980ti, and comes with 2 more GBs of VRAM though that doesn't matter for video editing, it's the quadro cards from nvidia that are seemingly a rip off with the pricing.
https://linustechtips.com/topic/565186-workstation-build/#findComment-7428565
Instead of LGA 2011 V3 you could go with the older 2011 LGA and get two E5 2670s on Ebay for about 140ish. That would give you 16 cores and 32 threads at 2.6GHz with a 3.3GHz boost. The dual socket motherboard will cost you about 400ish though. Still a great deal and you can get 64GB of ECC DDR3 for about 130ish. It will definitely beat the 2620 V3 at rendering.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/565186-workstation-build/#findComment-7430562
