19 minutes ago, RoanEngland said:
I have a western digital caviar blue 1tb 7200rpm hdd. I have had it for a couple months now, but it's been making buzzing noises, I was just wondering if that was normal
Hard drives make all weird noises. It's normal and if no data has gone missing then you're fine.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/565179-hdd-wierd-noise/#findComment-7428484
3 hours ago, RoanEngland said:
~snip~
Hey there RoanEngland :)
HDDs are mechanical units and as such it's normal to make noises and to produce vibrations (due to the moving/spinning parts in the drive).
The drive may also cause some resonance with the case or with the cables and thus produce more noise than normal so I'd check if it's mounted properly and solidly.
If you want to be on the safe side that the drive's health is good I'd make sure all the important data is backed up and I'd run WD Data Lifeguard Diagnostic tool in order to see if the drive passes both the quick and the extended tests. If it does the drive should be considered safe to use.
You can also check the raw values of the S.M.A.R.T. status with a third-party tool. Feel free to post them here if you are not sure how to read them. :)
Feel free to post back if you happen to have any questions!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/565179-hdd-wierd-noise/#findComment-7428871
