Need Advice On A Case
Go to solution Solved by STRMfrmXMN,
Just now, jkeasley said:
Ok here are my requirements:
- Silent
- Good cable management
- 1 2.5" bay
- A lot of 3.5" bays
- Door on the front (so that it looks clean)
- At least 2-3 ODD bays
- Must fix ATX
- USB 3.0
- Window
Define R5 windowed... seems about as obvious as can be!
- Silent
- 1 2.5" bay
- Must fix ATX
- USB 3.0
- Window
https://linustechtips.com/topic/565142-need-advice-on-a-case/#findComment-7428180
16 minutes ago, jkeasley said:
I was looking at the cooler master silencio and the thermaltake supressor f31.
Was also looking at the Corsair 330R
- Silent
- 1 2.5" bay
- Must fix ATX
- USB 3.0
- Window
Look at the DeepCool Kendomen.
I have one and it's pretty nice.
https://linustechtips.com/topic/565142-need-advice-on-a-case/#findComment-7428226
