Hi guys.
I'm trying to build a pc using the
Cooler Master Elite 350 (CMP 350) casing.
AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition Processor
MSI R7 370 GAMING 4G Graphics Card
MSI Computer ATX DDR3 1066 Motherboards 990FXA GAMING
Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3 CL10 DIMM - Black (HX318C10FBK2/16) ram
Will this be a ok gaming computer?:/
https://linustechtips.com/topic/565041-building-a-pc-need-help/
It won't do much of anything without a power supply.
How it preforms depends on what you will be doing.
What will you use it for and what's your total budget?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/565041-building-a-pc-need-help/#findComment-7427305
6 minutes ago, Electronics Wizardy said:
Id get a i5 or a i3 over a 8350.
For gaming probably not an i3. Although a new skylake i5 like the 6500 would be good. (however this involves more expensive Mobo and DDR4 Ram, bumping up the cost) or you could get a haswell i5 (though older, and no ddr4)
in general Intel will cost more but tend to be better, so if your on a budget stick with the 8350, as they are still very good
https://linustechtips.com/topic/565041-building-a-pc-need-help/#findComment-7427387
You don't need an fx 8350, go down to a FX 6300 or Athlon x4 (on the fm2+ platform)
I am guessing case comes with a PSU, don't use a case PSU,  XFX and Seasonic have good PSUs for $30.
You don't need 16GB of ram, drop it down to 8GB
A r7 370 is shit. Get a R9 380 2GB or 4GB instead.
You don't need a top tier motherboard,  get the cheapest AMD 970 motherboard with USB 3 headers if you are getting a FX 6300.
You don't have a HDD in that list.
https://linustechtips.com/topic/565041-building-a-pc-need-help/#findComment-7427408
will Gigabyte AM3+ AMD 970 SATA 6Gb/s USB 3.1 Motherboards GA-970-Gaming be fine with FX 6300
https://linustechtips.com/topic/565041-building-a-pc-need-help/#findComment-7427466
