So lately when I have been playing games I've been getting weird texture issues. I'm not sure what triggers it but it's happened in 3 different games now but the only way to fix it that I know of is to restart my game. I am not sure what it is if my card is dying or if it's a software issue. This is what is looks like: EeZTRxq.jpg
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/564921-artifacting-problem/
if you're on the latest Nvidia driver, roll back.
https://linustechtips.com/topic/564921-artifacting-problem/#findComment-7426130
How do I do that?
https://linustechtips.com/topic/564921-artifacting-problem/#findComment-7426138
1 minute ago, Matt_Twinkletoes said:
How do I do that?
use DDU and download 361.75
https://linustechtips.com/topic/564921-artifacting-problem/#findComment-7426147
Just now, calieburger said:
Have you overclocked your GPU?  and what is your GPU and cpu cooling look like? Temps?
GPU isn't overclocked and the temps on GPU didn't get higher than 71 and CPU didn't get higher than 50 degrees
https://linustechtips.com/topic/564921-artifacting-problem/#findComment-7426180
