Any way to turn off power to 4pin fan header on MB?
Solved by airdeano,
well since the headers of the motherboard are fan headers, the case no one would need
to turn off a fan is less likely. on PWM function, the % cycle time lowest value is 30%
in some cases. but most are 60%. so there is no value to 0% or 0volts.
only solution would be to run lights from source and install an interrupt switch to
toggle the power on and off. and best circuit would be the ground of the lights.
airdeano
