Evercool Buffalo 1366socket cooler fan replacement.
Vash Baldeus
Well first of all currently I don't have enough to buy a Noctua cooler, so I thought that replacing the original fan on my current one could give me a bit more quiet noise wise and maybe better airflow through the cooler.
My question is, should I get a noctua fan and replace the current one or just save up for a cooler?
Stampede
CPU: R9 5900X
COOLER: Noctua NH-D15
MOBO: X570 Aorus Pro (rev 1.2)
RAM: Corsair Vengeance LPX 4x8GB
GPU: EVGA FTW3 RTX 3080
The hyper 212 Evo is a great cooler and probably costs just as much as a new noctua fan (at least in scotland). so the 212 Evo it totally worth it
P.S i think it supports 1336 but don't quote me on that.
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
I'll just quote your post xD
Anyway, I was thinking replacing the fan itself on the cooler.
And yea' if I will be replacing the cooler then it will definitely Noctua.
They are quiet, easy to install and mount, also easy to remove if needed.
Stampede
CPU: R9 5900X
Ok no worries :P
Just now, ProKeero said:
Ok no worries :P
The question is should I replace the fan meanwhile, or save up money for the cooler..
Stampede
CPU: R9 5900X
Unless its dieing you should save up for a cooler.
It's alive, my issues is noise and temperature being a bit high..(reason GTX960) usually before I got it the temps were about 10 degrees lower.
And summer where I live is ruthless heat wise..
EDIT:
My dads rig,
I5 6600
16GB
GTX980
with Antec P100 & noctua cooler is so silent and cool you need to triple check if you turned it on..cause it's so quiet...
Stampede
CPU: R9 5900X
If You hate noise then yea replace the fan if you really hate it. whatever works for you dude :P
