Have a Hot 4440 i5 Haswell need help
Solved by MechanicalEngineer,
Check that the CPU heatsink is seated properly with the pins coming all the way through on the other side of the motherboard.
Sounds dumb, but it's surprising how many times it happens, stock Intel coolers are prone to this issue because they're a bitch to install properly.
ariaselm ·
3
StafVanderbruggen ·
Posted in PC Gaming2 -
Edward78 ·
Posted in Peripherals0 -
2
call me al ·
Posted in Windows1 -
Mando772004 ·
Posted in Peripherals1 -
alehop ·
Posted in Servers, NAS, and Home Lab2
