3 hours ago, Christian_Bell6 said:
Hi, I am getting this build http://pcpartpicker.com/p/MJmVsY Will the selected PSU be sufficient ? If not then what PSU would anyone reccommend. Thx
Yeah that is actually overkill. Look in the top left and it tells you the wattage you need.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/563963-psu-power/#findComment-7416314
3 hours ago, CurlyCucumber said:
PCPP's wattage estimate isn't always the most precise.
True, but they are generally close give or take 100 watts. That is a lot normally but with this build even if PCPP was of by 200 watts the OP would still be good.
https://linustechtips.com/topic/563963-psu-power/#findComment-7416341
Unless you're planning to SLI, the PSU is overkill. Tone it down to the EVGA SuperNOVA 650 G2.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/563963-psu-power/#findComment-7416406
