I have been having trouble with recording using OBS recently. I record in 1080p 60fps and whenever there is high motion, the video gets very grainy. I have tried messing with the setting and nothing seems to work. I tried to see if fraps recorded better, and I just got a black screen. Is there a way to fix the high motion scenes in OBS?
https://linustechtips.com/topic/563924-obs-video-quality-issues/
turn bitrate up?
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7415908
10 minutes ago, Fausto315 said:
shoudnt be an issue, at 3300
9 minutes ago, Fausto315 said:
I could, just dont have a whole lot of experience with it.
3300 is barely enough to maintain high quality frames at 720p@60fps let alone 1080p.
ShadowPlay is really just click and go :P Open Geforce Experience, set your hotkeys, and that's it!
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7415986
ye i changed my bitrate to 4300 its better, ill try to see if shadowplay is better.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7415991
30Mbps (yes Mbps not Kbps like OBS) is a good place to start on ShadowPlay.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416001
shadowplay is not working at all. i am signed in and everything is greyed out and it is not recording anything.
What version is your GeForce Experience? Cos they changed the UI recently.  I personally use 2.10.2.40 cos the new Beta ones started giving me problems a few days ago.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416049
Just now, Fausto315 said:
thats what im using
Did you click the ShadowPlay button at the top right? It should bring up a separate menu with an On/Off switch on the left.  Flip it.  Then back in the regular ShadowPlay settings, set where you want your FPS counter and Status Indicator on the monitor image on the right.  I personally like FPS on the right and indicator on left, both top side.  Go in-game, you should see the FPS counter pop up, then hit your record key and the indicator should change.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416090
I recorded and its not letting me watch it. just giving me an error message.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416091
You managed to record?  What are you trying to view the video on? What player?  And did you stop the recording first?
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416096
i got it. it was already recording i thought you had to press a button then press it when you were done.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416100
So we good here? :D Enjoy the higher FPS cos your CPU isn't being taxed by OBS recording.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416105
ye basically I was just being an idiot. thanks for the help ill definitely using shadowplay more often it's WORLDS better than OBS.
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416138
this is true. Just make sure to hit the manual start/stop when you know your going to be recording something. Goodluck :)
https://linustechtips.com/topic/563924-obs-video-quality-issues/#findComment-7416717
