Im biudling a pc and right now i will need  331 W and people recommend me buy 500 W
Which next year i will be getting new grafics card and i will need 414 W people recommend me buy 600 W
So witch on should i get 500 W or 600 W
plaing to buy:
Corsair CXM Builder Series Modular ATX/EPS Power Supply Unit, 80 Plus Bronze Certified
Please help
https://linustechtips.com/topic/563826-power-supply-help/
What are your build specs? What GPU are you planning on getting?
Honestly, the Corsair CX series aren't good.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/563826-power-supply-help/#findComment-7414610
plaing to buy:
Please help
What are your system specs? What is your budget?
https://linustechtips.com/topic/563826-power-supply-help/#findComment-7414943
SeaSonic is known for great power supplies and this is a decent priced power supply for a 80+ bronze unit. If you want a modular unit it is about $20+ more. Good luck! http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096&cm_re=seasonic_620-_-17-151-096-_-Product
https://linustechtips.com/topic/563826-power-supply-help/#findComment-7416772
My pc specs are:
Asus Motherboard Z97-P
ASUS AMD Radeon R7 240 2 GB DDR3 Graphics Card (PCI Express 3.0, HDMI, DVI-D, 128-Bit, Dust-Proof Fan, GPU Tweak Utility)
Intel Core i7 i7-4790K CPU (Quad Core 4GHz, Socket H3 LGA-1150)
Corsair CW-9060021-WW Hydro Series H100i GTX High Performance All-in-One Liquid CPU Cooler - 240 mm Radiator
DDR3 32GB RAM (4x8)
And i plan to buy over the year of having the pc i will buy second graphics card:
MSI AMD R7 370 Gaming Graphics Card (4 GB, OC, PCI-E 3.0, GDDR5, DVI-I, HDMI)
So what power supply should i get so that i would not have to change it over the year and keep it even when i get the graphics card ?
https://linustechtips.com/topic/563826-power-supply-help/#findComment-7418259
Do you have those parts already? If not, what is the intended used of this computer? If this is primarily a gaming rig, you could save a good deal of money getting 8GB-16GB of RAM instead and getting an i5 4690k instead and investing in a more powerful GPU now.
Generally speaking, a quality 550w should be plenty for a single GPU setup. Can you provide a link to the store you are buying from, so we know what's available to you?
https://linustechtips.com/topic/563826-power-supply-help/#findComment-7418448
