Editing PC Upgrade Help
Solved by runit3,
Under $300 in the last section
http://pcpartpicker.com/p/CXhVsY
Knocked off all but 2 of the pretty blue fans and swapped the board for an H97. A caveat would be if you planned on running a RAID on a separate SATA controller for completed file archives (how I currently run mine). I haven't run into an H97 with controller port segregation, and since you're upgrading an existing system it would be inadvisable to swap over to RAID from AHCI. I can try to hunt down a Z97 if that's something you feel like you may need in the future, can always go the NAS route too.
