what do mean by sound oriented?? audio production or a sound system for songs listening and stuff??
Yeah what exactly do you mean by audio oriented? Do you want to use it for audio production or possibly for a stereo system? You need to fully explain this...
https://linustechtips.com/topic/5624-computer-for-audio/#findComment-62877
May I suggest the bitfenix prodigy, a beautiful case. But I don't know many other Mini-ITX cases if this one is too expensive.
CPU : Intel Core i7 3960X, Mobo : X79-UD3, Memory : 4x4GB Vengeance Black Memory 1600MHz, GPU : Asus GTX 970 Strix, Case : Switch 810 Matte Black, Storage : 256GB Samsung 830 SSD, Seagate Barracuda 1TB, PSU : Thermaltake 750W 80+ Bronze, Displays : 3x Asus 1080p Screens, Cooling : Corsair H100i, Keyboard : Logitech G710+, Mouse : Madcat Cyborg R.A.T.7, Sound : Sennheiser HD598, V-Moda Crossfade LP, Logitech Z-5500, HMD : Oculus Rift CV1
https://linustechtips.com/topic/5624-computer-for-audio/#findComment-63201
I'm doing a build for a friend' date=' sound oriented. Not absolutely sure which way to go. No graphics card needed, so on-board with an i5 will do. Has a budget. Was thinking a Mini-ITX build with a xonar essence card. 8 gigs of vengeance 1600, i5 3570k, asus P8Z77-I deluxe. Not sure which case to use yet. Any input on the build is much appreciated. [/quote']
You tell us he has a budget but you don't tell us what it is :P
Anyway, as brought up what exactly do you mean by "sound orientated"? Is he chucking like an M-Audio PCI card in for 8 track recording or what's the story?
I've also flagged this to get it moved to the right subforum :)
https://linustechtips.com/topic/5624-computer-for-audio/#findComment-63253
Data here
I'm doing a build for a friend, sound oriented. Not absolutely sure which way to go. No graphics card needed, so on-board with an i5 will do. Has a budget. Was thinking a Mini-ITX build with a xonar essence card. 8 gigs of vengeance 1600, i5 3570k, asus P8Z77-I deluxe. Not sure which case to use yet. Any input on the build is much appreciated.
https://linustechtips.com/topic/5624-computer-for-audio/#findComment-63256
