pc issue HELP!!!!
Solved by papapoi,
i would call msi and not even try to power it up again in case it damages any other components, unfortunately its not like the old days when the manufacturer would have a copy of the the chip layout so you could pinpoint what was wrong, when you do get another motherboard i would just try to boot up barebone(mb,cpu,memory) then add in the video card and hd after it posts. hopefully your other components are unaffected.. just in case though check if any of your other components are under warranty
