Im running an 1150  I-5 4690K OC to 4.3GHZ and stress test says it hits 76C, is that too hot for my CPU?
System Specs
CPU: I5 4690K 3.6-3.9GHZ  1150   (OC 4.3GHZ)
MB: ASUS Z97-ProGamer 1150
RAM: 16GB G.saw 2166
GPU: Nvinda GTX 980 TI Windforce G1 seris
PSU: thermaltake 1050watt
OS: windows 8 pro
Main Drive: samanuig evo SSD  850 500GB
HHD: 2TB westerndigtal Black 7200 RPM
CPU cooler: cooler master 212 evo
https://linustechtips.com/topic/562153-my-cpu-too-hot/
Yeah, its a bit high for max usage. Maybe reapply your thermal paste on your CPU.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393581
Just now, Savir said:
No that should be fine. If you are worried maybe buy a better cooler and some more case fans.
my case is  Thermaltake Core V71 Extreme Full Tower   http://www.newegg.com/Product/Product.aspx?Item=N82E16811133244&cm_re=thermaltake_core-_-11-133-244-_-Product
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393596
1 minute ago, Helltechpc101 said:
There are several ways to lower temps by a little if you really want to. Applying better thermal paste, buying high quality fans, lowering overclock. It shouldn't be a concern.
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393614
ATM i know its fine, right now at winter my room stays cooler, but summner hit might reach 90C,  80C below is fine at 100% CPU load. once it hit 90 its too hot.
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393635
Thats actually finejust fine.  As long as it stays under 85C under load,  dont worry.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393648
ok good i may have to oc when winter and take it off in summer iof i must. but ill watch it as time gose by, becasue at the moment my room is 79F  and hightest core was 65C ATM, but since i OC'ed it i never get it too 100% CPU load.
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393671
There's actually nothing wrong with running a cpu at 90C, it is designed to run at that temp,  but certainly not recommended though.
https://linustechtips.com/topic/562153-my-cpu-too-hot/#findComment-7393947
