So here's my problem:
I'm looking to build my 1st PC. I would like to do some streaming and heavy video editing. Pretty generic goals but I am a newbie: 4K at 60fps, max settings, any game, one monitor.
Other parts:
ASRock Fatal1ty X99X
i7-5820K
G.Skill Ripjaws 4 DDR4 3000 memory (64GB)
Probably an SSD for W10 and SSHDs for data
Final Notes: I know this is a thirsty card and don't want any recommendations other than the # of cards that I could use and perhaps some cooling advice.
https://linustechtips.com/topic/561937-r9-390-problems/
Other parts:
i7-5820K
Im confused, your building the PC, is it already built? how do you know there is a problem ??
CPUIntel i5-6600k - Mobo - MSI Z170A M3 Gaming - RAM - 16GB G.SKILL DDR4 2133 -  GPU - MSI R9 380 4GB
CASE - Corsair Cube 540  CPU COOLER - Hyper 212 EVO - PSU - EVGA 1050w
https://linustechtips.com/topic/561937-r9-390-problems/#findComment-7391107
for 4k Fury X crossfire is a very good option
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/561937-r9-390-problems/#findComment-7391181
1 minute ago, max_headroom said:
It won't even happen at 1440p.
I would say 980ti SLI would probably give you 4K 60fps at high.
I understand this I am asking how many cards I need to get this standard. This card supports QuadFire and instead of getting 1 expensive $850-$1000 card, I'm getting a certain number of 390s so I can achieve 4K 60fps. It's also because there is often shutter with 1 and even 2 card setups for lower AMD cards, but it wouldn't be a problem w/ a 390.
https://linustechtips.com/topic/561937-r9-390-problems/#findComment-7391193
Ryzen Ram Guide
https://linustechtips.com/topic/561937-r9-390-problems/#findComment-7391261
Not even a single 980ti is going to give you 60 FPS max settings 4K.  The video card industry has lagged behind for a couple years in development lacking a new mark to aim for past 1080/1440.  Pascal/Polaris GPUs are allegedly the fix to that issue and will focus on 4K as standard.
You're better off waiting for Polaris/Pascal if you want 4K.
https://linustechtips.com/topic/561937-r9-390-problems/#findComment-7391436
