2 minutes ago, Alexzz_ said:
Noctua fans are the best silent fans i know of, however they are pretty expensive.
imo noctua fans being silent is quite misleading from my experience... my case's stock fans (Noctis 450) is even more quiet than the nf-f12 i own
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/561777-silent-fans/#findComment-7389565
The Noctua NF-A14's are the way to go, they have quite a high static pressure and airflow, while being very quiet
i5-6600k @ 4.9Ghz | Corsair H110i GTX + 2 x Noctua NF-A14's | ASUS Maximus VIII Ranger |
Corsair Venegance DDR4 8GB | ASUS GTX 970 Strix |Samsung 840 EVO 240GB + 1TB HDD |
Corsair RM850 | NZXT H440 Black | 2 x Noctua NF-F12 + Corsair AF-140
https://linustechtips.com/topic/561777-silent-fans/#findComment-7389577
well if your fans are too noisy due to high rpm, u can add another set of fan and do push pull, and lower the rpm for same amount of air flow
in that case, a pair of fan from any reputable fan company will be silent at low rpm
https://linustechtips.com/topic/561777-silent-fans/#findComment-7389586
25 minutes ago, Nagariss said:
NF-A14 FLX?
Get the PWM version, there will be more control over the speed of the fans, on a H110 they're  virtually inaudible, even at high rpm
https://linustechtips.com/topic/561777-silent-fans/#findComment-7389698
Bequiet is on par with Noctua.
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/561777-silent-fans/#findComment-7390562
3 hours ago, Nagariss said:
ok.
Are the Bequiet pure wings 2 good for rads?
Chose bequiet over noctua, i use silent wings, the best money ive ever spent on anything for my pc
Built  Not Bought
https://linustechtips.com/topic/561777-silent-fans/#findComment-7390565
