C2D running EXTREMELY hot
Go to solution Solved by tendstofortytwo,
Changed to E2140. I'm at a much more reasonable 35 degrees now. Thanks to all who replied.
Hey.
I have with me right now a machine with the following specs:
Intel Core 2 Duo E6300
ASUS P5-GCMX (the 1066 MHz one, not the 1333 one)
ZOTAC GeForce 210
3GB DDR2
160GB hard drive, Corsair VS450, random case
I can't help but notice that the CPU always runs very, very hot. I have nothing but four tabs in Google Chrome open right now, and Speccy reports 72-74 degrees Celsius.The GPU is around 55-60 degrees, which I think is okay because the card is passively cooled - no fan, just heatsink.
I've underclocked the CPU to 1.2 GHz right now, but there seems to be no improvement. Help?
PS: I also have a Pentium E2140 as a last resort if this chip doesn't run cool.
“Forgive me my nonsense, as I forgive the nonsense of those that think they talk sense.” — Robert Frost
https://linustechtips.com/topic/561157-c2d-running-extremely-hot/
I would do a good dusting and thermal paste replacement, as I was using a low-profile heatsink which was about on-par with a C2D's stock heatsink on a Q6600 and it barely passed 67C.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
3 minutes ago, TheWoollyMammoth said:
I presume you are running a stock cooler, which for c2d was a piece of crap. Also, the stock thermal compound could have dried up starting to work as insulation rather than dispersing heat.
3 minutes ago, WarWeeny said:
Replace thermal compound and the problem is no more.
Just now, gFrenken97 said:
It's a C2D, what do you expect?
Replacing the thermal paste or buying a better coole ris all you can do.
I am on a stock low-profile cooler, but I have cleaned the CPU and replaced the thermal compound with Cooler Master IC Value V1. I realize this may not be the best, but I had it lying around and it worked well on my i5, or at least as good as new stock compound anyway.
I have very recently rebuilt this entire PC from scratch, clearing out all the dust I possibly could.
Buying a cooler isn't currently an option. Since many of you seem to suggest the C2D has had heat problems with the stock cooler, the E2140 should work fine, right?
