Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/56110-fan-controller-help/#findComment-757194
NZXT SENTRY 2
Ninjaed :c
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/56110-fan-controller-help/#findComment-757197
Its a 3 pin
All of these are 3 pin!!!!!!!!
Use a converter
https://linustechtips.com/topic/56110-fan-controller-help/#findComment-757341
Its a 3 pin
You can easily cut the plastic on the connectors so a 4pin goes in.
or a converter.
https://linustechtips.com/topic/56110-fan-controller-help/#findComment-757344
Where can I find converters?
ebay ;p
https://linustechtips.com/topic/56110-fan-controller-help/#findComment-757366
