hey folks im hitting about 75 *c while folding on my 3770k paired with a h80i around 44 ish *c idle, thse temps obviously aren't that great ...  im not to worried about hitting 75 *c as i have some good headroom before i enter the danger zone, but i do wish that the temps were lower, and i probably wont be overclocking a whole lot .. heh yeah that's the thing .. im currently at stock speeds/voltages
is this normal, or just a tad bit too high? possibly trying to change thermal paste and reseat the water block?
090820133111
currently got it mounted with the tubes top down but that really shouldn't be a problem?
https://linustechtips.com/topic/56066-3770k-with-h80i-temps/
How many fans and what kind of fans do you have on it?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/56066-3770k-with-h80i-temps/#findComment-756478
is the fan spinning properly? is there a proper spinning fan on it?
LOL are the temps THAT bad? xD, well i got two Noctua nf-f12's on it so .. shouldn't have any problems there, i can feel a pretty decent airflow if i put my hand behind the case.
the radiator itself seems pretty cool, so i might not get enough heat transferred away from the cpu and to the liquid?
https://linustechtips.com/topic/56066-3770k-with-h80i-temps/#findComment-756507
I would re-seat the CPU block again to make sure.
https://linustechtips.com/topic/56066-3770k-with-h80i-temps/#findComment-756530
seeing at the temperature of the h80i itself is about 35 *c and the cpu is 75 *c yeah .. something is definitely wrong :P i posted a picture of how i got it mounted in the first post, i guess il just have to re-seat the cpu block once i get my hands on some new thermal paste and see if that helps .. as something is obviously pretty wrong here :P
https://linustechtips.com/topic/56066-3770k-with-h80i-temps/#findComment-759466
