If you want it sparking clean, disassemble the whole pc and clean the parts one by one. I recommend cleaning with an electronic duster. It costs more than air cans, but its more powerful and effective and does not run out of air, so its cheaper in the long run.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
https://linustechtips.com/topic/560525-pc-cleaning/#findComment-7375903
Well, there isnt anything "dirty" about it, just some dust that needs cleaned up.
https://linustechtips.com/topic/560525-pc-cleaning/#findComment-7375910
3 minutes ago, bart69132 said:
there is just some around the handles, apart from that there isnt anything i can see
then why are you asking if there isn't anything to clean that you can think of....
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/560525-pc-cleaning/#findComment-7375941
