xbox wireless controller
Go to solution Solved by UnlimitedTMD,
try to push your batteries REALLY far in, helped with mine, watch this kid do it (it actually works):
Good day, I need help.
I just purchase xbox 360 wireless controller. I installed the driver then plug in the wireless receiver on the usb port at the back of my pc, after that when i press the logo on the controller it won't light up. Doing some research on the internet, they said that there should be a mark on the device manager but when i check mine it's not there. I don't know what to do next. i check the battery and it has power. Please help me.
OS: windows 8.1
Rig: CPU: Intel I7 4790k @ 4.5 ghz | MOBO: MSI Z97 Gaming 3 | RAM: 4x4 gigs Kingston Fury 1600 ddr3 | GPU: MSI Geforce GTX 1070 Gaming X PSU: Seasonic M12ii-620 Evo Edition | HDD: 1 TB WD, 500 GB WD | SSD: Kingston SSD now 240 and 120 GB CASE: In Win 303 RGB edition | Mouse: Corsair m65 pro | Keyboard: Roccat Ryos MK | Headset: Hyper X Cloud Pro  | Monitor: LG 29um58-P Ultrawide monitor.
https://linustechtips.com/topic/560515-xbox-wireless-controller/
make sure to hold down the logo, not just press it
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/560515-xbox-wireless-controller/#findComment-7375845
OMG, thanks a lot, i placed the battery the wrong way. I saw 2 spring at the bottom so i thought that is is + - and + - but it should be - + - +. My bad.
Thanks for the reply. didn't bother to check if i correct placed the battery the right orientation
https://linustechtips.com/topic/560515-xbox-wireless-controller/#findComment-7375858
