Hello Techies :) - I recently upgraded to a R7 370 4gb, im running one vga 22" screen as a side monitor, its using the DVI adabter obviously, 1st screen is a 24 inch dvi lg monitor, sometimes whenever i use youtube or other video sites on my 2nd monitor, my 1st screen just crashes, looks like an oldschool dead gfx card screen. Sometimes i can save it by pressing once on the power button on the pc to get to the choose an option screen then its fine again, but most of the time i have to reset. Here is a picture of my current system, as you can see i have clocked the old i5 lynnfield to its maximum. Same as the card. Thank you :)
https://linustechtips.com/topic/560235-problem-with-dual-screen-setup/
I could be wrong but maybe its because your using a vga adapter. Do you have a
DVI-I and DVI-D connector on your card. When I used a adapter I had to make sure I was plugged into the DVI-D port I believe.
