Hello everyone I thought I would ask here because everything I have done isn't working. I am having a big problem with my computer getting too hot. Is my first computer that I have successfully built by myself but the temperature does concern me sometimes. I will list the specs and my findings
Specs
Processor: i7 4790k
GPU: Nvidia GeForce GTX 970
Motherboard: z97x-Gaming 7
Case: Bit fenix Colossus
Cpu Cooler: H100i
Fans: 3x Arctic F12 pwm pst
Monitors: 3x Philips 22"
So when i am playing games my computer likes to get really hot and to combat this i have been using the PrecisionX software but it makes my computer sound like a jet. I would really like my computer to be some what quiet but i just don't know what to do.
When playing cities skylines i have noticed that my CPU has reached temps of 75 Celsius and my GPU is kept at 60 - 65 Celsius.
I also bought a NZXT case a couple months ago which is beautiful but i can't use it because it gets way too hot. Any advice would be appreciated.
https://linustechtips.com/topic/559432-heat-problems/
Cities Skylines is a VERY CPU bound game, so it is likely to peg your CPU at max load for a good chunk of time. 75 C isn't terrible for a stress test, so I'd be temped to say it isn't bad here, but if it is concerning, you could always re-apply thermal compound, or try re-seating the CPU, or lastly, just clean any dust from the H100
¢υѕтσм ℓσσρ σя ησтнιηg αт αℓℓ
https://linustechtips.com/topic/559432-heat-problems/#findComment-7362099
Thats not too hot, the room temp is one of the hardest things to keep down. I struggle with that problem myself and i have the same specs.
| MOBO MSI Z97 Gaming 3 | CPU i7-4790K @ 4.7GHz | RAM G.Skill 16GB 2133MHz | SSD Kingston 240GB / HDD Seagate 3TB | GPU MSI Gaming GTX 970 |
| Cooling CM Nepton 240M | Display Philips BDM4065UC 40in 4K | Keyboard Corsair K70 Cherry Blue | Mouse Logitech G502 | Case Fractal Design Core 2500 |
PSU Rankings
https://linustechtips.com/topic/559432-heat-problems/#findComment-7362124
The GPU temps look just about right. The CPU is a little on the hotter side, especially with that AIO cooler. Which game gets it up to 75C?
PS: Why can't you use that case? It allows for great airflow, it's not going to make anything run hotter.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/559432-heat-problems/#findComment-7362246
3 minutes ago, Dobbythenerd said:
When on cities skyline it gets to about 75 but the GPU is at 60-62 when the fans are like jets
Oops, reading fail, I now see you mentioned the game in the OP. Cities is very demanding on the CPU, but it still sounds a little on the high side to me. Have you applied the thermal paste yourself or used the one that was pre-installed on your AIO cooler? Also, have you stress tested the CPU alone with software like AIDA64?
Edit: As for the GPU, after some point you will find that raising the fans too high won't make much difference. And having the same card I can tell you, running it at above 60C is perfectly normal. So just find a fan curve that's good enough and comfortable to your ears at the same time.
~ Specs bellow ~
https://linustechtips.com/topic/559432-heat-problems/#findComment-7362275
due to the non-standard of PCB thickness of the motherboards, some are really thin and allow the pump/controller to fit loosely. the rubber o-rings tighten the "looseness" and apply a bit more clamping pressure to the IHS of the CPU and the coldplate of the pump/controller. a 3mm hole and 1mm o-ring cross (makes that a 3x5 o-ring) will fill that gap and allow some compression of the stand off if the PCB is thick.
https://linustechtips.com/topic/559432-heat-problems/#findComment-7364441
