Im planning to do some custom sleeving for my psu and I have a few short questions for you guys.
1. Is it necessary to use tinned wire or is normal copper alright ?
2. Is 17 AWG enough for the main ATX and PCIE power cables ?
Thanks for all answers and have a nice day :D
https://linustechtips.com/topic/558846-custom-psu-cables-question/
17AWG isn't a size it would be either 18 or 16 AWG where the most common is 18AWG or the larger 16AWG can also be used if desired. The wire can be a bare copper or tinned they're isn't really a lot difference for this application.
For more details on wires and sleeving check the Modding FAQ under Sleeving:
17AWG is a size, please don't spread misinformation.
Tanks for your answer. Im from Germany so I bought 1mm² cables thats about 17 AWG so that should be fine :D. And thanks for the link to the modding thread
Ive still been debating Custom sleeving my own cables vs Corsair's aftermarket cables vs @CableMod cables.
imho reusing your old cables and just resleeving is probably marginally easier than creating all new cables from essentially scratch.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
which PSU are you planning to use?
Corsair AX760 (the tricky non-'i' version) which I believe falls under your C-series (with a different 24pin cable or something like that).
Don't want to hijack @St4rkill3r's thread though.
You can use it no problem :D @ThatCoolBlueKidd
And Im doing mostly all cables from scratch I have a bit of experience in doing custom cables from my holiday job so sleeving them shouldnt be a huge deal
Right now Im waiting for the PSU to release in EU (EVGA T2 1000)
got it - if you purchase a C-Series we will send you a free AX760 24PIN cable - email us to community@cablemod.com if you are interested.
