So I have the Cablemod rgb led widebeam strip kit and I want to set up one strip on the bottom and on the top but to do that I need to have one strip on the bottom and one on the top and something connecting them without lighting up. So can I just buy some kind of extension cable to wire them or do I need to buy a led strip and take the leds out or something?
https://linustechtips.com/topic/558719-led-strip-spacer/
I'm not sure if Cable Mods directly have some from their site but there are extensions like theses that are for RGB based LED's:
http://www.amazon.com/TronicsPros-Strip-Connector-Extension-Ribbon/dp/B016KSOMM2/ref=sr_1_9?ie=UTF8&qid=1456975479&sr=8-9
EDIT: I believe their it has two power leads which you can run from the controller so you can run one up top and one to the bottom.
Edited by W-L
https://linustechtips.com/topic/558719-led-strip-spacer/#findComment-7352355
