Fan upgrade choice?
Go to solution Solved by roctrebira,
3 minutes ago, LightCode Gaming said:
Not bad if you dont mind the german flag color cables :). They should be decently quite.
So I have some spare cash, and I'm thinking about getting 2 more fans for my case. (Look at image for reference)
The top of my case can take 120mm and 140mm fans. Two of them. One directly above the Hyper 212 and one towards the middle (the drawing is crude and not 100% accurate, sorry ><)
My questions are:
Should I do 140mm or 120mm in them?
Which way should I have them pointing? AKA intake or exhaust?
120-140Fans.png.cc21c3a23d948e5becbd2ede
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/558572-fan-upgrade-choice/
My questions are:
Are you having any heat problems? If not then I wouldn't even bother getting new fans and just use the money on something else you want.
[CPU-i5 4690k] [MB-Asus Maximus VII Hero] [GPU-Asus Matirx 980ti] [Ram-8GB Corsair Vengeance ram] [ Cooling-Corsair H100i/ 3 Noctua NF-P12 for intake] [sSD/HDD-120GB evo/ 1TB WB Caviar blue] [Case-NZXT H440] [Dell U3415W]
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351021
Well, my GPU (below the hyper 212 in the picture, not pictured) gets to about 55C when gaming, and CPU goes to about 50C. The fan on my GPU gets decently loud around 53C, so I'm hoping this would lower the temps a bit.
I'm not sure if either of those temps are problems, but I don't like them going up any higher so I'd like to bring them down if possible. The fans and power splits wouldn't cost me too much either.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351034
Yea both those temps are around 30c below when you start running into problems. If you find the gpu fan loud just get MSI afterburner and lower the fan speed and just make the gpc stay under 80c and all will be good. My 980ti runs from 70-80c while gaming.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351045
I wouldn't upgrade. Think about positive air pressure. If there is dust filter in front, having more intake will help keep your computer clean.
And 50*C for CPU and GPU is perfect.
If you want to experiment you could try to borrow Puget Systems idea.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351047
So what you are saying is I could use my pc as a hand warmer? xD
I know I'm getting at least 1 fan though; for the hyper 212. Should 70's be good enough and safe for my gpu? especially if it's blowing right onto my PSU?
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351053
Oh yea 70s will be perfectly fine and what fans were you looking at for your 212?
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351060
How about if I found this deal? http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351061
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351080
Thats the plan :D
Now to find splitters...
http://www.newegg.com/Product/Product.aspx?Item=N82E16812987008&cm_re=fan_splitter-_-12-987-008-_-Product
This look good? I'd need to get 2 of them if they work.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351102
Thats the plan :D
http://www.amazon.com/Swiftech-8W-PWM-SPL-ST-Way-PWM-Splitter-Sata/dp/B00IF6R4C8
Just grab that.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351105
Wouldn't the one I linked do the exact same thing?
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351108
Pretty much the swiftech just lets you control all the fans off one header insted of multiple. Aslong as they are PWM.
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351147
I think I'm going to just go with the 2 splitters at $4.99 or whatever it was. Cheaper and still fits my needs. Thanks for the help though!
https://linustechtips.com/topic/558572-fan-upgrade-choice/#findComment-7351186
