2 minutes ago, Samfisher said:
6 fans seem a little overkill TBH :)
I May Downgrade I Was Thinking Of:
  1. Input (so There's Actually Air In The System)
  2. Cpu (like Every Normal Computer Has)
  3. Graphics Card (Bare Card)
  4. Hard Drive (my Hard Drive Gets Quite Hot Well Downloading)
  5. Output 1 (Near Psu)
  6. Output 2 (Near Pci / Chipset)
Thanks For Replying Ill Bear Your Suggestion In Mind. :)
I'm A Cactus !
https://linustechtips.com/topic/558001-fan-controllers/#findComment-7345030
Some quick viewing to help your needs :)
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/558001-fan-controllers/#findComment-7345037
1 minute ago, KE2012 said:
Yeah, you probably wont have that many fan headers on your motherboard, so you will likely have to resort to Y-splitters or even molex. I would look at something like NZXT Grid+
I May Get Rid Of My Output 2 And Hard Drive Fans Previously Mentioned On My Post
I'm A Cactus !
https://linustechtips.com/topic/558001-fan-controllers/#findComment-7345053
Just before you buy check how many fan headers your motherboard has! Otherwise you will be stuck on molex or y splitters!
https://linustechtips.com/topic/558001-fan-controllers/#findComment-7345075
Ok Thanks
If I Have 6 Fan Headers Ill Get All 6 Fans And A Fan Controller,
If I Have Less Ill Get The Most Important Fans And Ditch The Fan Controller.
I'm A Cactus !
https://linustechtips.com/topic/558001-fan-controllers/#findComment-7345272
