Normal.
Maybe get a better PSU though?
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/557286-cx430m-noise/#findComment-7337906
It's a fan.
Try pushing it inwards with something like a pencil with a rubber or something. Use some force until it pops further in. That's what corsair said when I had a problem like you.
If that doesn't help, try lubricating it or replace it yourself, RMA it or buy a new PSU.
I need S340. But more Define S'ish
https://linustechtips.com/topic/557286-cx430m-noise/#findComment-7337962
4 minutes ago, Allshevski said:
It's a fan.
I will try it and see if it works
https://linustechtips.com/topic/557286-cx430m-noise/#findComment-7338005
I ended up replacing the fan with Noctua NF-F12 PWM. Now its super quiet, the only noise from my PC is the Hyper 212 Evo fan which I may replace it soon with Noctua NF-F12.
Thanks to @MG2R for his video https://linustechtips.com/main/topic/6392-knex-server/
I connected the fan directly to the PSU and monitor it throw the motherboard
https://linustechtips.com/topic/557286-cx430m-noise/#findComment-7382049
