i want to put in my aquarium LED lighting
i found that the CAR led modules will fit except they running at 12v
there any way to run them from 5v without voltage buck boost? or 12v battery?
Case: NZXT H440 CPU: i7 6700K @ 4.0 Cooler: Antec Kuhler H2O 920 Graphics Card: Zotac Mini GTX1070 Ti Motherboard: Gigabyte Z170 K3 RAM: Kingstone Fury 2x8GB Storage: Crucial P1 SSD, Seagate - Barracuda 2TB 3.5, Hitachi - Deskstar 500 3.5" PSU: Corsair Enthusiast 550W 80+ Mouse: Logitech G403 OS: Windows 10 Home 64bit  Audio: ATH-AD500X
https://linustechtips.com/topic/557051-led-modding/
Not really, no. It's highly unlikely that the LEDs would have such a large range of operating voltages. LEDs can have it, sure, but if it's a proprietary unit, they've probably opted for the cheaper LEDs with narrower range. Why not just get a 12V AC/DC adapter for it?
https://linustechtips.com/topic/557051-led-modding/#findComment-7335359
when i finished to write this post i remembered that i have old 12v 1a( or 2a) from router
https://linustechtips.com/topic/557051-led-modding/#findComment-7335381
now i just build 12v hub
https://linustechtips.com/topic/557051-led-modding/#findComment-7335384
If it is a must they run at 5V there are 5V based LED strips that are mainly used for plug in USB type connections.
https://linustechtips.com/topic/557051-led-modding/#findComment-7336457
just checked them they good but not what i need
this better:
https://linustechtips.com/topic/557051-led-modding/#findComment-7337587
