Just now, Stephg2525 said:
Hey guys, before i begin yo build my rigs, i want to know some tips to make a good cable management setup.
What's your tips ?
Do you know any video about it ?
Thank's
Make sure you buy a decent case. Fully modular PSUs help a lot. Make sure your case has lots of cable management holes. For effectiveness, dont buy a mATX motherboard
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334541
There's nothing wrong with an mATX board. But an mATX board will generally not look very good in an ATX case.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334550
I have one and it's horrible for cable management. I'm talking about cable management holes at the side with the mATX headers at the bottom of the motherboard
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334556
Pick a better case, there are plenty of cases with cable management holes along the bottom as well, that's not exclusive to ATX.
PSU Tier List | CoC
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334563
Use a lot of zip ties. If your lazy about cable management, you could find a dual chambered case instead.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334566
4 minutes ago, Stephg2525 said:
I'm looking for a mAtx motherboard but with the Corsair 350d who like prety nice for cable management
There's not THAT much space back there, even though there is. The 24pin makes the middle of the panel bode out just a tiny bit. There's a decent amount of tie down points in the back, so that will help out with cable management.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334581
Ummm, there's quite a bit of space behind the tray in the 350D. It's actually incredibly easy to cable manage in.
PSU Tier List | CoC
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334586
I know there is, but for someone who is very OCD about very nice cable management, there isn't. I've spent roughly 10-12 hours cable managing in the past 2-3 years.
https://linustechtips.com/topic/556969-cable-management-tips/#findComment-7334589
