Hey, i am looking to upgrade my computer
right now, these are the specs
GPU: 6870
CPU: AMD Phenom ii x4 940
Motherboard: Asus M3A-78T
Ram: 4GB DDR2
So i am looking to upgrade it, as i mentioned but i want some suggestions to what to upgrade,
i have a 400$ budget, in Canadian and have windows 10 right now, heard something about that and needing to buy a new copy or something.
So can i get some advice? Thanks!
https://linustechtips.com/topic/556927-cpumobo-upgrade-help/
Are you gaming or doing something else? If you're just gaming I would recommend holding off until you can afford a GPU upgrade as well.
And yes, you could potentially need a new windows license if you have an OEM key, although you can sometimes transfer OEM keys as well with the help of Microsoft.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/556927-cpumobo-upgrade-help/#findComment-7334067
Yeah, i am just gaming
the gpu is holding fairly well right now, in GTA 5 the most demanding game i have the CPU usage is max but the gpu seems to be only 50-60%
https://linustechtips.com/topic/556927-cpumobo-upgrade-help/#findComment-7334077
Well, then go with something like this and then just upgrade the GPU when you get a chance/decide you need more power.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($274.25 @ Vuugo)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($78.50 @ Vuugo)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($47.21 @ DirectCanada)
Total: $399.96
Generated by PCPartPicker 2016-02-28 21:46 EST-0500
You can also go with a Haswell i5 instead if the above is too expensive: http://ca.pcpartpicker.com/p/8FDzzy
PSU Tier List | CoC
https://linustechtips.com/topic/556927-cpumobo-upgrade-help/#findComment-7334098
yeah definetly an intel i5 upgrade...i5-4460 and H97 if money is really low...otherwise i5-6500 and H170 and if money is no problem i5-6600K and Z170,,,you will want a GPU upgrade soon after look for GTX 970 or R9 390 (used GTX 780/780ti or R9 290/290X also viable options) or wait for next gen GPU's.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/556927-cpumobo-upgrade-help/#findComment-7334182
