  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/556658-case-for-budget-build/#findComment-7331370
The Fractal Design Core 2300, I hear.
If you're willing to shell out a bit more, get the Phanteks Enthoo Pro M.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/556658-case-for-budget-build/#findComment-7331945
