This depends on your usage. If you are simply gaming then two or usually even one 8GB stick should serve you fine. There's a great LTT video that you should watch for more information. If you are also questioning the speeds of RAM then no fear. There's one for that too.
https://linustechtips.com/topic/556414-ddr4-memory-help/#findComment-7336270
