Hey!
Looking for suggestions on cpu coolers that cost under $100 AUD.
I'm going to be running an i5-6600K :^)
Intel Core i7-7700K | Noctua NH-D15 | ASRock Z170 Pro4 | G.Skill Ripjaws V 2x8GB DDR4-3000 | Seagate BarraCuda 2TB 7200RPM | Samsung 970 EVO Plus 250GB NVMe M.2 | Gigabyte WINDFORCE OC RTX 2060 Super 8GB | EVGA SuperNOVA 650 G3 | Corsair Obsidian 750D | TP-Link Archer T4E | DeepCool FH-04
Yet to acquire... Seagate BarraCuda 4TB 5400RPM | 2x Silicon Power A55 2TB | 2x Simplecom SC501 | ICY BOX IB-863-A
https://linustechtips.com/topic/556408-air-cooler-suggestions/
NH-D15 got my for 100 AUD but i just check now it around 110 dollar mark, is best air cooler you can get.
Magical Pineapples
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329166
I was thinking the NH-L9i, but I'll check out the D15 :)
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329179
Just now, CaptainGunny said:
Yes, spend a bit more and get D15
Okay :)
Tried updating my build on au.pcpartpicker but the D15 never showed up :?
It showed up when I searched it earlier though :/
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329188
1 minute ago, natalieisabutt said:
Okay :)
https://au.pcpartpicker.com/part/noctua-cpu-cooler-nhd15
Here you go.
Magical Pineapples
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329195
Just now, Moonzy said:
make sure your case fits the d15, its a huge cooler, the largest i think
I'm getting the Corsair SPEC-02
Mid-Tower
Not sure if it fits .3.
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329205
3 minutes ago, huilun02 said:
The NH-D15 is AU $115+ everywhere in Australia
https://www.pccasegear.com/category/207_23/cooling/cpu-cooling
https://www.ple.com.au/Categories/Cooling/CPU-Coolers/Air-Coolers
http://cplonline.com.au/coolers.html?brand=151
Consider the other Noctua 140mm series coolers. The D15 is top of the line yes but its also big and more than what you need.
Personally it worth the investment if fit the case. If you want best of best air cooler NH-D15 is one to get, other 140mm is around 100 dollars mark but the if you not able to fork up 15 dollars this is another option (https://www.pccasegear.com/products/29593/cryorig-r1-ultimate-cpu-cooler) perform the same but a bit louder.
Magical Pineapples
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329213
D'you know what Mid Towers fit the D15? I don't need anything too expensive and I found the Deepcool Tesseract at $55 AUD
I hope it fits it >~<
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329223
2 minutes ago, Moonzy said:
Corsair Spec-02
Maximum CPU Cooler Height: 157mm
Noctua NH-D15:
Height (with fan): 165 mm
so no it wont fit, unless u change a case
The Deepcool Tesseract SW has a cpu cooler height restriction of 165mm, and it's cheaper than the SPEC-02
I'm guessing having it JUST on the mark is okay?
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329239
i wouldnt bet on it...
even if it DOES fit, having your heatsink scratching the side panel (if you have any) is a bad idea
not to mention it might make a ton of noise by transfering the vibration to the side panel if it touches
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329245
Any suggestions then?
all I need is a mid-tower that can fit 165mm + it has to be under $100 aud
https://linustechtips.com/topic/556408-air-cooler-suggestions/#findComment-7329252
