Posted February 28, 2016 Hi, I am planning for a itx build as it suits my current needs as it will be easy to move if i were to return to my home country since i am currently working overseas. For the moment i am looking at lian li pc-05 or silverstone rvz02. But of course if there are better suggestions around the size and form factor feel free to recommend CPU: i7 6700 (not going to OC but maybe do some editing hence hyperthreading) mobo: suggest me. (Will be using samsung 950 pro nvme m.2 ssd) psu : silverstone SFX series gpu : r9 nano(i will only be using this gpu) ram:ddr4 16gb storage : 3.5' is preferable however if not possible will be using hdd dock. So don't worry about hdd size when suggesting me a case Basically i need help in case and mobo selection. I will majorly do 1440p gaming so i believe r9 nano is sufficient. Dun worry about availability in my place. Just recommend me. I will find a way thru it. thank you in advance! Cheers! Marcus Link to comment https://linustechtips.com/topic/556403-mini-itx-build-need-help-on-case/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 28, 2016 Corsair bulldog if style is your type or you 380T graphite are some flashy cases. They some good ones from fractal as well as nod 202. Magical Pineapples
