4 minutes ago, pzsoltlego said:
Alright, so basically I have a CiT Xecutioner gaming pc case
http://www.amazon.co.uk/CiT-Xecutioner-Gaming-Black-Interior/dp/B00DOYT6FY
And I was wondering if there was any way to have a side panel window
Unless the case has a windowed panel that you can purchase it will most likely need to be modded or have a window cut into it. If you are interested in doing that I have a guide here in the updated Modding FAQ under Window Mod:
