need help with overclocking
Solved by vanished,
55 minutes ago, Mchedlo said:i got precision X only because it was from EVGA
i will download MSI afterburner then. will i get at least 5% difference in FPS with raising only clock speed ? (reaching limit, so that i dont have to crank up voltage )
That depends entirely on your card and luck of the draw (silicon lottery). It might not be able to increase at all, or you might have a really golden chip that can go quite a lot faster even on stock voltage.
Regardless, another thing you should do is raise the power limit as high as it will go. This does not force the card to run any harder, but it allows the built-in turbo to reach its full potential. It might show up as 110% or even more.
