13 minutes ago, CUDA_Cores said:
core speed can give you a small FPS boost, depending on the games. Most of us just go for the superclocked or FTW version just because it costs only a little more.
So buying the normal vs. the FTW wouldn't make the much of a difference?
https://linustechtips.com/topic/555970-core-speed/#findComment-7324856
