hey guys I make youtube videos and render them with Adobe Media encoder. I'm planning to get a couple Xeons and a dual socket board for a rendering server. now i'm wondering what the best graphics card would be for rendering?
right now I have a 980 ti and it only peaks at 30% every once in a while. so I was thinking maybe a Quatro of some sort? I want to stay with NVidia.
also any other recommendations for parts?
https://linustechtips.com/topic/555558-best-graphics-card-for-rendering/
Ignore me.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
Just now, Beeeyeee said:
whatever you'd like bud;)
I recommend a quadro card but that isn't really gonna help you. So I edited it.
Okay, so Adobe Media Encoder (which I use) doesn't use much of your GPU at all, at max, like you said around thirty percent. Certain export types will utilize it a bit more or a bit less, but nothing major. The best bet to increase performance is CPU cores.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
5 minutes ago, Beeeyeee said:
from what it seems , cuda support is better on adobe software , but maxwell isn't that great at compute . Amd cards with open cl is a great solution , but i have no idea ,how it reacts to opencl acceleration.
First of all , be sure not to use a quadro or a firepro , as they will not have any benefits over a geforce/radeon, while costing a lot more.
give me a bit more time , i'm checking how well adobeME reacts to gpu acceleration
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
so you'd reccomend no graphics card? do xeon's have integrated graphics?
the lower end quatro cards are fine.
Ok , from what it seems , gpu support on adobe ME is pretty bad ( uses about a third of the gpu ). In the end , for rendering ( strcily speaking ), it doesn't seem to make a huge difference here.
However , if you serious about rendering and you use a lot of software using cuda , an nvidia card would be a better choice. Otherwise , geta radeon , it has better raw compute . Just go according to your budget , but don't buy a professionnal grade card for video encoding . It won't help , and will cost multiple times as much
No, you want a GPU as it helps accelerate rendering in the timeline so you'll always be editing things smoothly like playing a video game, the GPU renders the frame buffer in the timeline and then the CPU does all the hardcore conversion to various file formats at the end and the GPU simply assists it.
the lower end quadros use very low end gpus ( like what you would find in a gt-class card ). Getting a consumer grade card with much more horsepower will help much more.
i'm going to edit on my main desktop. this server is purely for rendering and uploading
Then if this is just for rendering then forget the GPU and get as many CPU cores as your budget allows. Speaking of which what is your budget? and what is your main system?
