Automatically switch audio devices
Probably not. Typically applications will either have their own default audio device or will use the windows default.
The challenge with switching in this case is that, assuming you're plugging headphones in to your front panel or rear I/O, you're actually using two entirely different audio processors. Video card and chipset.
You might have better luck plugging the headphones in to the same device the HDMI puts the audio through, if it's a monitor with speakers it might automatically switch the output with the phones plugged in.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
I figured it out, I just set my headphones as default, and whenever I unplug them, the monitor becomes the default again. And when I plug them back in the headphones become the default.
Grump Bumb
I'm honestly surprised that worked, had so many silly issues with Windows and sound lately.
Good on ya mate.
There is another even more robust solution.
Search the program soundswitch. It takes less than 10 minutes to set up and it automates the process of swapping between sound outputs. This way with a simple keyboard shortcut (or in my case a mouse shortcut) you can instantly swap between speakers and headphones (I also have speakers hooked up through Displayport audio on my monitor).
You don't even have to remove your headphones to swap (I leave mine plugged in).
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
