V=x*y*z
Why do Java programmers wear glasses?
Because they don't C#
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/554888-java-project-error/#findComment-7313586
Assuming that this pool is just a rectangle the formula for volume is length * width * height (depth).
10 hours ago, DXMember said:
V=x*y*z
V is volume
x is length
y is width
z is depth
Give x, y, and z a value then apply the formula.
If you're trying to calculate the length, width, and depth of a pool, I'd suggest a tape measure rather than Java :D
https://linustechtips.com/topic/554888-java-project-error/#findComment-7316950
