3 minutes ago, courtiousdoge said:
i need a 5mm led (red) dont know where to get (note i have a motherboard from asus with  a aura connector) can some1 pleastelll me where to get 1 (online usa) and not maganetic?
don'T you have a radioshack near where you live ? or any kind of electronic store ?
or go to http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312823
are you looking for a literal LED bulb? or one with a connector attached?
Because a basic red LED can be purchased on amazon or at Radioshack.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312826
If I use words like probably or most likely, it is because I dislike certainty. These words can probably be omitted and the sentence read as a certainty.
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312866
Just now, courtiousdoge said:
umm 5mm not meter
Adafruit, Amazon or ebay will have stuff like this, but as for the aura connector those are designed for RGB LED strips and will not work with theses:
https://www.adafruit.com/product/299
-Moved to Modding Section-
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312899
k thnx can any1 fiind a 5mm rgb (non magnetic) rgb strip
They are readily available on Amazon by the roll:
http://www.amazon.com/SUPERNIGHT-Waterproof-300LEDs-Flexible-Controller/dp/B00B2F3KDQ/ref=sr_1_5?ie=UTF8&qid=1456417308&sr=8-5
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312931
umm 5mm not meter
I know what you meant but, i don't think they make 5 mm wide led strips
If he solders them into a row all in parallel and connects them to mobo right it will. Might be too high current draw tho. Just no GB of RGB.
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312939
see i specifically want a 5mmm becuz  i want it to fit in my reservoir
Oh ok well that would be a completely different setup, cause the voltage from the aura connector would not be correct for single 5mm LED dioides, and NTF is correct they do not make 5mm based LED strips.
For RGB based 5mm LED diodes you will need to set it up so it uses a resistor to drop he current for those LED's.
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312967
@courtiousdoge are you any good at soldering? if so you cold make a strip and use a pot to vari the voltage from the power supply and put a hole in one of the optical drive bay covers on your case and adjust brightness like that. If you need help ask.
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7312986
Performance-PC's.com
http://www.performance-pcs.com/catalogsearch/result/?q=5mm+led
Just got some individual and twin 3mm and 5mm LEDs for my EK blocks and pump/res.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7313005
Right.
5mm is the diameter of the indivual LED, there are strips that contain multiple 5mm LED's, but no 5mm wide strips(lol, that would be extremely thin)
https://linustechtips.com/topic/554827-5mm-led-red/#findComment-7313050
