Ok,
So I game, mostly FPS (Insurgency and Arma/Squad) heavy sessions 4-6 hours a time. My eyes suffer, particularly at long range in Arma/Squad etc.
I am about to embark on my new build, and would like your experience of the following formats, I'm a performance junky (just not very good.....) so need all the help I can get, and would like for my eyes to not suffer as much.
Option A
27inch TN LED 1080 at 120FPS (ok not Arma/Squad re server side limitations)
Option B
27inch TN LED 1440 at 60FPS
Which would you say is superior, and why? (The FPS is fixed at that level to avoid big drops and peaks etc).
I can't justify both the 1440 and 120FPS right now so need to decide!
CPU Intel i7 8700K @5Ghz Motherboard ROG Maximus Hero 10 RAM Corsair Vengeance 32GB 3600MHz
GPU MSI Gaming X 1080ti Case Thermaltake Core P3  Storage SSD Boot plus Samsung 960 Evo M.2 nvme storage
PSU Corsair RM750W Gold Display Asus ROG Strix XG32VQ 144Hz 1440p Cooling Corsair H100i V2
Keyboard Roccat Ryos MK FX Mouse Roccat Kone Aimo Audio MK3 Fostex T50RP + Schiit Magni 3 AMP and Modi 2 DAC
Operating System Win 10
VR HTC Vive, Audio Strap Motion Platform DOF Reality 2 DOF
https://linustechtips.com/topic/554816-help-me-decide/
I'd say 1440p if you do a lot of stuff that isn't gaming. If you mainly just game then 1080p@120fps (assuming your system can drive it).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7312696
Just gaming, if i go that way then it's better GPU, if I go the other way, better display.
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7312710
Arma is also a bitch on the CPU, so you'd also have to make sure your cpu could handle higher fps.
Honestly, it's a tough call to make. If you think that a smoother image will solve your eye problem (and if you can run it) then I'd definitely go for the 144hz monitor. If not, maybe IPS would be a better choice -- I personally find an IPS monitor more comfortable to look at due to better colors (which probably results in less eye straining settings)....
PSU Tier List | CoC
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7312760
Yes i have no experience of IPS Displays, so I guess my question is now -
Option 1
27 IPS display at 1080
or
Option 2
27 TN display at 1440
Purely from an eye strain and more accuracy at long range in Arma perspective!
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7312869
Option 1
or
Option 2
I wish I could give you an answer, but It really comes down to you. I just find that on TN panels I tend to raise the brightness to increase contrast (which can cause eye strain, but then again, increasing the smoothness with a higher framerate can also help...)
PSU Tier List | CoC
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7312907
or as my wife says maybe game 2-3 hours at a time and get a life? LOL
Appreciate the input, i'll try get hold of an IPS display and check it out and go from there.
https://linustechtips.com/topic/554816-help-me-decide/#findComment-7313009
