Hi,
Good day..
Just want to seek some of your professional tips/advise regarding building a PC.
I live in Dubai and have limited budget only. Project budget is around 1,000USD.  (some of the price here are a bit costly)
My main concern is I want to use the i7 and the GTX 960. Any suggestions on other parts is highly appreciated.
With a pretty descent case and CPU cooler on a budget is nice too.
Any recommendation of online store that has a cheap shipping cost that can ship in UAE.
CPU - Intel i7 4790
Motherboard - Gigabyte Z97 Gaming 3
GPU - Gigabyte GTX 960 2gb
RAM - Kingston Hyper x Fury 1600mhz - 2x8gb
SSD - Samsung Evo 120gb
HDD - Seagate Barracuda 7200rpm - 1tb
Power supply - EVGA Supernova G1 650watts
CPU cooler - Aerocool V6 GT
Case - Aerocool GT - A
PS I am going to use the build on gaming and some rendering works.
Thanks a lot in advance.
https://linustechtips.com/topic/554696-pc-build-advice/
No point in getting the i7 4790 with a Z97 motherboard. What you want is the Xeon 1231 v3 and a H97 instead.
The R9 380 would be the better choice unless you'll be utilising CUDA which I doubt. The R9 390 (or GTX 970, depending on which is cheaper) would be a great choice if it's within your budget.
The PSU isn't the best, try to go for the EVGA SuperNOVA 550W G2.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7311528
what this guy said ^^^^^
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7311548
Skylake?
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7311602
Thanks for your quick response. Budget is an issue. :)
I must stick on my GPU. (i hope just for now)
I'll check the price of this EVGA SuperNOVA 550W G2 if it's within my budget. What would you recommend for a budget of $100?
What H97 board can you recommend please? :)
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7311766
The 550W G2 should be under $100.
If not, any 500W PSU in tiers 1-3 from this list would be good choices:
As for the H97 motherboard; probably a ASRock Anniversary or ASRock PRO4.
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7311780
The ASRock Annie is nice.
Just wondering if the i7 4790 is worth it? or should I go with the i5 4690k?
thanks all for the responses..
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7329012
Pointless to go with the i5 4690K since you'll have to buy a Z97 motherboard to overclock it which will cost you more.
Like I said, the Xeon 1231 v3 is basically the same as the i7 4790 without the intergrated GPU and you can get it for the price of an i5.
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7329019
I saw that this CPU is categorize as a server CPU? Will this not be a problem?
Also, i'm confused with these two GPU. Searching local online store and found these. I can't see any difference aside from physical appearance and price?
https://gear-up.me/graphics-card/pci-express/gigabyte-gtx960-4gb-128-active-2xd-h-3xdp-w2-d5.html
https://gear-up.me/graphics-card/pci-express/gigabyte-gtx960-4gb-128-active-2xd-h-dp-d5.html
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7329171
Looks like a bigger blower design and it's slightly longer. I think that's why it's more expensive.
This specific Xeon is basically an i7 which means it'll be great for both gaming and rendering. You've got nothing to worry about.
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7329285
Thanks a lot for the help. Finalizing my build and hope to buy the parts soon.. :)
https://linustechtips.com/topic/554696-pc-build-advice/#findComment-7335099
