Need Help Installing Printer On Network
Solved by dragoon20005,
you first need to set an fixed IP address for the printer themselves
it will be in the printer settings page.
your router should have some sort of printer server feature as well if you can find it
that way your printer could also be connected to the router
so that you dont need to set any IP if you are not sure
